Cory's No Name Build
Postby blackthree4me » 09 Wed Sep, 2009 12:22 pm
that first ride up and down the street is the best one ever
or at least the most exciting :shock:
glad to see you on the down hill side most never get that far.
once you get it running better go over every bolt one more time
youd be suprised about the one you left loose.
Postby CoryN » 09 Wed Sep, 2009 12:40 pm
I agree - I found a couple of bolts laying out in the street after I put it away.
Postby Texasbuggys » 09 Wed Sep, 2009 4:41 pm
Great job Cory!!! Where is the taillights??? LOL
Postby CoryN » 09 Wed Sep, 2009 5:04 pm
Those rapid fires are cool. Got a lot of comments about them.
Postby Bill K » 09 Wed Sep, 2009 6:41 pm
Love your car, and love those '47 Plymouth taillights. 8-)
Absolutely AWESOME job. 8-) 8-)
Postby Texasbuggys » 10 Thu Sep, 2009 7:05 am
Cool they fit the back of your buggy great. Glad the tail lights worked out well for you Cory!
Postby CoryN » 10 Thu Sep, 2009 7:52 am
Actually, I had to take them apart and grind them down. Where I ended up putting them was perfectly flat, so I had to grind the arc out of the light housings to get it to fit.
Postby Mook » 10 Thu Sep, 2009 9:29 pm
what size wheels and tires do you have on there?
those things are huge!
Mook
Postby CoryN » 10 Thu Sep, 2009 10:11 pm
The rears are 15x10 with N50s on them
Postby Texasbuggys » 11 Fri Sep, 2009 7:38 am
Are so the back if the body is flat right there?
Postby CoryN » 11 Fri Sep, 2009 9:09 am
Yep - no curve at the point I decided to mount them.
Postby BrianB » 11 Fri Sep, 2009 10:00 am
I like how clean the lines are on the back of that Buggy 8-) There is no big cutout, just a straight line from side to side. KOOL
Postby GregR » 11 Fri Sep, 2009 11:19 am
Cory,
A couple of things. First, I like the e-brake on the right rear...I have one just like it. I've been thinking about staining it a nice dark maple color to cover the oil spots....but then the stains do give them character ;-)
The other thing is, Do you have your carb linkage disconnected? Is it a SCAT linkage? It looks like the arm to the passenger side is hanging too low at the pivot point behind the distributor.
Postby CoryN » 11 Fri Sep, 2009 11:27 am
Man you guys are good.
No the carb linkage is not hooked up on the passenger side, that is one of the bolts I found laying in the street.
Someone else noted that the pipes on the passenger side are discolored more than the drivers, true also. The right side is running hotter than the left, more compression on that side too. I'll probably have to rebuild it, but I was going to get it running and rule out all the other possibilities first.
And my ebrake is stained with fiberglass resin ;-)
Postby Aquabuggy » 11 Fri Sep, 2009 12:20 pm
Cory, your buggy's looking good man! All the hours of hard work really show, nice job!
I don't see a license plate light, where are ya going to mount the plate?
Postby BrianB » 11 Fri Sep, 2009 1:06 pm
If he mounts it to the crankshaft pully the popo will have a harder time reading it :lol:
Postby CoryN » 11 Fri Sep, 2009 2:10 pm
I've got the little led lighted bolts for the plate. I also pu a pair under the dash as courtesy lights. Notsure on the plate yet probably right in the center
Postby Aquabuggy » 11 Fri Sep, 2009 4:18 pm
CoryN wrote:I've got the little led lighted bolts for the plate. I also pu a pair under the dash as courtesy lights. Notsure on the plate yet probably right in the center
LED lighted bolts :? ya got a link?
I like Brian's idea mount the plate on the pulley.
This guy had the plate mounted way up under the rear of the body.
Kinda asking for trouble, red car, big a$$ turbo hanging out the rear and a plate hidden under the body.
Postby CoryN » 11 Fri Sep, 2009 4:32 pm
I got the little lights at walmart. They were like 3 bucks or so. Look in the pepboys section they work great as courtesy lights. A nice little dot right in the middle of the floor boards.
Postby staggerwing » 11 Fri Sep, 2009 7:30 pm
First thing I would check is if that right carb had a squirter tube that was dripping :shock:
Postby CoryN » 11 Fri Sep, 2009 8:25 pm
I was following your post with interest as I am almost certain it is after watching it run the last time I had it going a couple of months ago
Postby tx_1987_gta » 12 Sat Sep, 2009 8:23 am
Has anyone considered using one of these for the license plate? Im not sure where you would put it but sure might help hide it when the plate is not in use.... 8-)
http://www.stylintrucks.com/parts.aspx? ... ilyid=2100
Thanks Joe
1981 Turbo Trans Am
1987 Trans Am GTA " Magic "
tx_1987_gta
Wire harnes
Postby Algernon72 » 15 Tue Sep, 2009 7:34 pm
Do you have a drawing of the wire harness? I am up to the point where I am plumbing the brakes and putting in the wires...I have only the most basic stuff in it and one of the universal turn signal/hazard lights switches. I have done enough wires done to turn on and run the engine but lights are not my strong point. Any help will be great...even a hand drawing would be good. Thanks
Algernon72
Postby CoryN » 15 Tue Sep, 2009 7:38 pm
Pm me your email and I'll send you everything I have
Postby Fred » 15 Tue Sep, 2009 9:07 pm
Hey Cory, I would appreciate it if you'd CC me on that e-mail, I'm in just about the same spot, thanks Fred
Fred
Postby CoryN » 15 Tue Sep, 2009 10:18 pm
Ok I'll send them in the morning
Cory
Postby CoryN » 16 Wed Sep, 2009 11:16 am
emails sent
let me know if you don't get them. There were two.
Cory
Postby David Head » 16 Wed Sep, 2009 12:38 pm
Now that's what this site is all about.
What I always like to say is
"see one, do one, teach one"
It is great when the student becomes the teacher.
Re: Cory's No Name Build
Postby 10ovr » 06 Wed Oct, 2010 9:07 am
Cory,,Went through the whole tread,,,Great job,,Nice ,clean and simple,,The color looks great,,
10ovr
Postby CoryN » 06 Wed Oct, 2010 12:47 pm
Thanks but I still like your blue. Maybe next one
Cory
Previous
Users browsing this forum: No registered users and 70 guests
