or at least the most exciting
![Shocked :shock:](./images/smilies/icon_eek.gif)
glad to see you on the down hill side most never get that far.
once you get it running better go over every bolt one more time
youd be suprised about the one you left loose.
CoryN wrote:I've got the little led lighted bolts for the plate. I also pu a pair under the dash as courtesy lights. Notsure on the plate yet probably right in the center
Someone else noted that the pipes on the passenger side are discolored more than the drivers, true also. The right side is running hotter than the left, more compression on that side too. I'll probably have to rebuild it, but I was going to get it running and rule out all the other possibilities first.
Users browsing this forum: No registered users and 50 guests
