Hawk wrote:We use the cable from a super beetle. Or in the rails we build we will get the bus cable and shorten to what we need. Hope it helps!
Hawk wrote:I cut the the square drive off then get the old cable out of the square. pull the cable out of the housing, cut to length, I use a tool that is used for crimping cable rope to crimp the square back on.
Aquabuggy wrote:Hawk wrote:I cut the the square drive off then get the old cable out of the square. pull the cable out of the housing, cut to length, I use a tool that is used for crimping cable rope to crimp the square back on.
Cool, Ill have to try that.
Hey Neil are y'all still building the speedo pods (whatever there called) for rails like the one your dad is running?
Hawk wrote:I do still have the mold. I could make a couple if you want.
Aquabuggy wrote:I guess your asking about the cableit runs from the left front drum/disk dust cover through the center of the spindle then to the speedo.
Aquabuggy wrote:Well not sure about empi disc but Ive used the AC disc kit from So cal imports and it uses the same dust cover as the drums.
Does your spindle have the hole in the center? If it does then you should be good to go.
Aquabuggy wrote:If there is no hole in the spindle Id call the place that sold you the kit, that just doesn't sound rite, but hey what do you expect it's EMPI!
Is this a ball joint or link pin?
Only other thing I know to do is buy a GPS that will display your speed.
Jerry wrote:I did check...! Is a lowered spindle from EMPI. It has no hole in the inside of the left or right at all..! nothing..!
Bill K wrote:I think what you will need is a VW front wheel bearing dust cover. The dust cover has a small squarish hole in the middle of it. The end of the cable goes through the hole and there should be a groove in the end of the cable to receive a clip that keeps the cable in place. The rotation of your hub dust cover then turns your speedo cable.
