Matching a AE case to early swing axle.
Postby David Head » 03 Tue Nov, 2009 12:40 pm
Is there any clearance issue putting 1600 AE case on a 1967 swing axle tranny. Assuming you have the right T. O. bearing and clutch set up. Do the splines fit and will the flywheel fit into the bell housing??
Postby jspbtown » 03 Tue Nov, 2009 1:26 pm
I "think" the 1967 was the first year for the 12 volt. If so, it should have the 200mm flywheel and will bolt right up with no problems. If it was the 6 volt you just need some clearancing which is easy.
I also suggest a started from an autostick. Much better option.
