Low and Slow
Low and Slow
Postby CoryN » 07 Sun Mar, 2010 6:10 pm
Got things put back together today
Buggy sat too high up front
So I pulled the beam
Had to make an adjustment to allow me to narrow it while putting in adjusters
And welded it all back up. The new chrome tie rods were shorter than the originals and had enough threads I didn't have to cut them. Got the alignment dead on, it tracks a straight line with no hands on the wheel. I can go lower, but it hits the leading edge of the fender right under the headlight when I turn hard either direction. I can modify that edge and go lower, but I'll wait until I get the new 4 inch wide Mickeys up front before I do.
Been out driving around in the rain this afternoon :D
Postby S/C4095 » 07 Sun Mar, 2010 9:32 pm
Nice work! Looks sharp Cory. Did you repaint the car also?
S/C4095
Postby Bill K » 07 Sun Mar, 2010 9:39 pm
SO FINE 8-) 8-)
Postby CoryN » 07 Sun Mar, 2010 9:40 pm
Haven't repainted yet. But still plan to
Postby BrianB » 08 Mon Mar, 2010 6:39 am
Looks great Cory.
Postby Bryan Porter » 08 Mon Mar, 2010 9:48 am
How close do the shocks come to the tie rods when you turn sharp.
Postby CoryN » 08 Mon Mar, 2010 10:12 am
Plenty of clearance on the shocks. Only issue I have is if I turn all the way to the right the inside edge of the passenger tire will rub the tub. Not the other way though. Is there a way to make a stop so it won't go that far?
Postby BrianB » 08 Mon Mar, 2010 11:05 am
CoryN wrote: Not the other way though. Is there a way to make a stop so it won't go that far?
Add a bigger motor and drift around the corners instead of using the steering wheel :lol: :lol:
Postby jspbtown » 08 Mon Mar, 2010 12:51 pm
OEM beams have adjustable steering stops on the beam near the box. Anything on your old one that can be transferred?
