Nooner wrote:buy a harbor freight 20 ton press and a set of their 3/4" Sockets - Viola!!! Everything you need to press in wheel studs, and you can turn very big bolts/nuts too! I am surprised the local shops didn't have a press... maybe they were just being lazy because it is hard to charge you for 5 minutes of work. Last time I had to buy wheel studs I ended up having to order them in too - but I needed a very specific application and had to look them up in the Dorman catalog.
BrianB wrote:You should have paid the $40 a wheel to have it done where you bought them from. Sounds expensive but in the end you are ahead time wise.
