On first blush, the packaging is adequate, however, the instructions are not. They are incomplete at best. With a little electrical knowledge, and some common sense, installation should not prove too troublesome. All wire is color coded and labled the entire length of the wire. The fuse panel is 21 circuit (including the starter circuit) and utilizes Mini blade fuses. It comes with several male and female plugs, and the horn, and light relays, as well as the turn and hazard flashers.
In all, I am well satisfied.
