Tail lights
Tail lights
Postby CoryN » 16 Fri May, 2008 12:25 pm
Anyone ever consider going with something like this?
They are flush mount, from the back, basically you cut a hole just for the size of the lens and sand flush. Might be kind of cool 8-)
Postby CoryN » 16 Fri May, 2008 12:27 pm
Forgot to add, they come in all shapes and sizes
Postby Vee Dub Nut » 16 Fri May, 2008 12:33 pm
Those are pretty cool...
Since the back of my body is trimmed up so high I'm pretty limited on my choices.. thinking I'm going to have to have something mounted on an engine cage
1967 Beetle
2000 GTi
Vee Dub Nut
Postby CoryN » 16 Fri May, 2008 12:38 pm
I believe Bryan Porter has some little LED's mounted on his engine cage for tail lights
Postby jspbtown » 16 Fri May, 2008 12:45 pm
You would probably have to use an electronic flasher as most LEDs don't have the required resistance to activate the standard flashers.
Postby CoryN » 16 Fri May, 2008 12:55 pm
Out of curiousity, are flashers generally required equipment?
Postby Vee Dub Nut » 16 Fri May, 2008 1:13 pm
I think he means you cant use the traditional three pronged flasher relay.. since LED's have low resistance, they don't blink correctly..
As for hazzard lights.. My gut feeling is that you can probably get by without them. At least the places I've been inspected.. There was a checklist floating around somewhere...
1967 Beetle
2000 GTi
Vee Dub Nut
Postby Vee Dub Nut » 16 Fri May, 2008 1:14 pm
1967 Beetle
2000 GTi
Vee Dub Nut
Postby Bryan Porter » 16 Fri May, 2008 1:35 pm
You are right about the flasher
What I did was put a bulb in
the turn indacator light to
work the flasher.
